Novice muffler install - advice needed |
pugface |
Mar 19 2017, 04:29 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Hi guys
Often time when I am trying to do some work on my car, I find instructions that skip certain things because 'everybody knows' some steps. Unfortunately, I don't know all the little tips and tricks. I just pulled off my exhaust - the car came with a a Bursch glasspack exhaust that makes a terrible sound. My car also came with a bunch of spares, I thought I'd try the stock muffler that came in the pile. Although there were no gaskets when I removed the old muffler, I assume there should be? Also, occaasioanly I see reference to copper nuts, copper paste, anit-seize - are there extra things I should be doing besides just using a new gasket and a bolt from Ace hardware? I would like to be able to get this muffler off in a year or so, so any tips are appreciated! Thanks pf |
GeorgeRud |
Mar 19 2017, 10:21 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I've always used the gaskets and regular bolts with anti seize, washers, lock washers, and nuts from the hardware store to attach the mufflers. I wouldn't recommend using the nylon locknuts as they might melt with heat from the exhaust. They've always worked and have unbolted when needed to swap out the muffler. I think you'll prefer the stock banana muffler to the rather noisy Bursch.
porschetub |
Mar 19 2017, 10:45 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I've always used the gaskets and regular bolts with anti seize, washers, lock washers, and nuts from the hardware store to attach the mufflers. I wouldn't recommend using the nylon locknuts as they might melt with heat from the exhaust. They've always worked and have unbolted when needed to swap out the muffler. I think you'll prefer the stock banana muffler to the rather noisy Bursch. great answer and (IMG:style_emoticons/default/agree.gif) ,just don't do them up crazy tight no need,if you have a leak put some exhaust sealant paste in there,you will be good. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 09:03 AM |
