Mars on a budget, 75 914 field-find into cool driver |
Mayne |
Mar 20 2017, 08:39 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
I thought I'd formally introduce my 914 project, now that I've been lurking on this great forum for a while.
A little back story: my younger brother and I are car fanatics, especially those of the German variety. He owns multiple BMWs, an early 911 with RS bodywork, and a manual 928, and I own an early Boxster, a 944 Turbo, and now the 914. Last summer, my brother went to check out an E36 parts car for his M3 in rural New Mexico. Sitting under some trees was this solid but rather forlorn looking 914: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063976.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.2.jpg) $1800 later, we towed home a mouse infested ran-when-parked 75 914. The 1.8 FI engine had been swapped out for a 1.7 with 1.8 heads and a single Weber carb, and the impact bumpers had been backdated to chrome bumpers. Mars Red with Mahle gas burners! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.3.jpg) It had been parked because the previous owner thought it had developed a serious front main seal leak. We got it running with a minimum of effort and saw the significant oil leak. We impulsively dropped the motor and resealed the oil pump, suspecting that might solve the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.4.jpg) Motor back in, along with a dual Weber setup we came across, it seemed like the leak was fixed. But it was running so badly, we couldn't really drive it. Since my brother was working part time at a Ferrari shop that primarily builds vintage motors, we were able to get the carbs rebuilt for cheap by the excellent Ferrari mechanic. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.5.jpg) Now with the car running much better, two thing were apparent, 914s are fun (IMG:style_emoticons/default/driving.gif) and we didn't fix the oil leak. (IMG:style_emoticons/default/WTF.gif) About this time, my growing love for this 914 was finally too much to resist. So my brother and I made a trade on his half of the purchase price for a ran-when-parked manual 928 that I had picked up. Still not sure who ended up with the better half of that deal, but we're both happy! With the car mine now, I started in on some of the needed projects. Thanks to 914World, I solved the major oil leak with a bolt in thermostat pulley hole (quite a bit easier than dropping the motor). With that dealt with, I could see a decent driver on the horizon. More soon! Cheers, Jeremy |
Literati914 |
May 27 2022, 08:30 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
This is coming along nicely Jeremy, I’m following your build especially now that your doing the conversion Suby (I got one of them too that I’ll be dealing with eventually) - good work so far (IMG:style_emoticons/default/smilie_pokal.gif)
A couple things I wanted to ask about - what exactly did you do to the dash? .. and also, I was wondering how much of the original ‘lumpy’ texture from the factory was on your roof when you shot it with the rocker guard? Did you sand it smooth first or go over original texture? Yours looks nice but I’m considering using it over a well aged original texture roof and was hoping for some of the original dimensionality to come thru. Not sure if doing that would produce good results though. . |
Mayne |
May 28 2022, 06:08 AM
This is coming along nicely Jeremy, I’m following your build especially now that your doing the conversion Suby (I got one of them too that I’ll be dealing with eventually) - good work so far (IMG:style_emoticons/default/smilie_pokal.gif) A couple things I wanted to ask about - what exactly did you do to the dash? .. and also, I was wondering how much of the original ‘lumpy’ texture from the factory was on your roof when you shot it with the rocker guard? Did you sand it smooth first or go over original texture? Yours looks nice but I’m considering using it over a well aged original texture roof and was hoping for some of the original dimensionality to come thru. Not sure if doing that would produce good results though. . For the dash, I used red body filler (for small scratches and pinholes) to fill in cracks, sanded, then painted it with flat black vinyl paint. It has not held up too well, so the next step will be to put on a moulded dash cover that I have hanging around. Eventually, I hope to just do a complete 914Rubber dash. For the top, I just sprayed the rocker guard over the existing texture. I’m not sure if it was original. The rocker guard doesn’t build up much texture on its own, so I think you’d be fine to spray over what you have. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:17 AM |
