Mars on a budget, 75 914 field-find into cool driver |
Mayne |
Mar 20 2017, 08:39 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
I thought I'd formally introduce my 914 project, now that I've been lurking on this great forum for a while.
A little back story: my younger brother and I are car fanatics, especially those of the German variety. He owns multiple BMWs, an early 911 with RS bodywork, and a manual 928, and I own an early Boxster, a 944 Turbo, and now the 914. Last summer, my brother went to check out an E36 parts car for his M3 in rural New Mexico. Sitting under some trees was this solid but rather forlorn looking 914: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063976.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.2.jpg) $1800 later, we towed home a mouse infested ran-when-parked 75 914. The 1.8 FI engine had been swapped out for a 1.7 with 1.8 heads and a single Weber carb, and the impact bumpers had been backdated to chrome bumpers. Mars Red with Mahle gas burners! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.3.jpg) It had been parked because the previous owner thought it had developed a serious front main seal leak. We got it running with a minimum of effort and saw the significant oil leak. We impulsively dropped the motor and resealed the oil pump, suspecting that might solve the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.4.jpg) Motor back in, along with a dual Weber setup we came across, it seemed like the leak was fixed. But it was running so badly, we couldn't really drive it. Since my brother was working part time at a Ferrari shop that primarily builds vintage motors, we were able to get the carbs rebuilt for cheap by the excellent Ferrari mechanic. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.5.jpg) Now with the car running much better, two thing were apparent, 914s are fun (IMG:style_emoticons/default/driving.gif) and we didn't fix the oil leak. (IMG:style_emoticons/default/WTF.gif) About this time, my growing love for this 914 was finally too much to resist. So my brother and I made a trade on his half of the purchase price for a ran-when-parked manual 928 that I had picked up. Still not sure who ended up with the better half of that deal, but we're both happy! With the car mine now, I started in on some of the needed projects. Thanks to 914World, I solved the major oil leak with a bolt in thermostat pulley hole (quite a bit easier than dropping the motor). With that dealt with, I could see a decent driver on the horizon. More soon! Cheers, Jeremy |
76-914 |
Jan 26 2022, 10:53 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
He should be OK. Here are both of my Subaru conversions and their openings for reference. On the 70 with the green & yellow bumper I cut out 5 of the centermost holes creating an oval opening and it cools fine. Jeremy is using 7 holes and has opened up smaller holes in-between each of those. Worst case is he'd need to open it up by removing the material between the holes. The EZ30's don't require much of an opening. Even with AC. HighJack over.
tazz9924 |
Jan 28 2022, 03:42 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
He should be OK. Here are both of my Subaru conversions and their openings for reference. On the 70 with the green & yellow bumper I cut out 5 of the centermost holes creating an oval opening and it cools fine. Jeremy is using 7 holes and has opened up smaller holes in-between each of those. Worst case is he'd need to open it up by removing the material between the holes. The EZ30's don't require much of an opening. Even with AC. HighJack over. I like how you did that, i wish i cut my hole open like that in a past life instead of cutting the bumper out so much. What does the backside of that look like? i went through the fender wells but i do really like the floor exit for non race car kinda swaps. I was just more worried about exit, but he is right that he can cut more holes. Especially with ducting it’ll be better. If theres good water proof ducting and you have the grating, why not just cut it out so you don’t need to figure out if it works good enough on a hot day. Keep up the work though! |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:06 PM |
