Mars on a budget, 75 914 field-find into cool driver |
Mayne |
Mar 20 2017, 08:39 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
I thought I'd formally introduce my 914 project, now that I've been lurking on this great forum for a while.
A little back story: my younger brother and I are car fanatics, especially those of the German variety. He owns multiple BMWs, an early 911 with RS bodywork, and a manual 928, and I own an early Boxster, a 944 Turbo, and now the 914. Last summer, my brother went to check out an E36 parts car for his M3 in rural New Mexico. Sitting under some trees was this solid but rather forlorn looking 914: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063976.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.2.jpg) $1800 later, we towed home a mouse infested ran-when-parked 75 914. The 1.8 FI engine had been swapped out for a 1.7 with 1.8 heads and a single Weber carb, and the impact bumpers had been backdated to chrome bumpers. Mars Red with Mahle gas burners! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.3.jpg) It had been parked because the previous owner thought it had developed a serious front main seal leak. We got it running with a minimum of effort and saw the significant oil leak. We impulsively dropped the motor and resealed the oil pump, suspecting that might solve the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.4.jpg) Motor back in, along with a dual Weber setup we came across, it seemed like the leak was fixed. But it was running so badly, we couldn't really drive it. Since my brother was working part time at a Ferrari shop that primarily builds vintage motors, we were able to get the carbs rebuilt for cheap by the excellent Ferrari mechanic. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.5.jpg) Now with the car running much better, two thing were apparent, 914s are fun (IMG:style_emoticons/default/driving.gif) and we didn't fix the oil leak. (IMG:style_emoticons/default/WTF.gif) About this time, my growing love for this 914 was finally too much to resist. So my brother and I made a trade on his half of the purchase price for a ran-when-parked manual 928 that I had picked up. Still not sure who ended up with the better half of that deal, but we're both happy! With the car mine now, I started in on some of the needed projects. Thanks to 914World, I solved the major oil leak with a bolt in thermostat pulley hole (quite a bit easier than dropping the motor). With that dealt with, I could see a decent driver on the horizon. More soon! Cheers, Jeremy |
rick_cv |
Jul 2 2022, 01:53 PM
Newbie Group: Members Posts: 33 Joined: 3-March 09 From: PNW Member No.: 10,125 Region Association: Pacific Northwest |
Can I ask what you are going to use for engine management (ecu)? I keep seeing that you can't use the EZ30 stock ecu and have to purchase a standalone from private companies which is expensive and may not be fully featured.
Mayne |
Jul 2 2022, 03:01 PM
Can I ask what you are going to use for engine management (ecu)? I keep seeing that you can't use the EZ30 stock ecu and have to purchase a standalone from private companies which is expensive and may not be fully featured. Yes, this is sort of the elephant in the room when it comes to the EZ30R. Before I started ordering parts, and especially the engine, I felt confident that I would be able to use a fairly basic Link ECU. As I continued researching (after having bought the engine) and opening up lines of communications with several ECU companies, I became convinced there is only one truly well-developed ECU for the this engine at this time: Haltech Elite 2500. It is the only ECU I've found that has base start up maps for the 30R and can accommodate the DBW, Variable Cam Timing, Variable Valve Lift, and CanBus conversion that are inherent in the EZ30R. So, once you're done spitting your last swig of beer all over the room, you try to come to grips with that reality. I pretty much have, and while it will be some time before I can spring for the Haltech and harness materials (seriously planning to build my own harness to understand how it all went together), I actually feel pretty good about it. And if that gets me closer to maximizing the potential of this swap, then I honestly believe it's money well spent compared to the other build/swap alternatives. To take this just a bit further, I have heard of people successfully getting their 30Rs running in 914s and even Vangons, but I have yet to see any real video of this in action. So, while those JDM sixes with all their high tech look good, do your due diligence before you plunk down your money. Or just hang in there with me for another year or so, and see if I actually get this thing to work. I'm starting to work on a video series on the swap for my brother's YouTube channel, so this won't be the only place it will documented. Long response here, but I was going to have to address it sooner or later! |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:29 PM |
