Leaking, valve cover gaskets. |
Elliot Cannon |
Mar 20 2017, 09:03 PM
On the way home from the Phoenix Club event, I noticed a slight aroma of burning oil. A smell by the way that I am sad to say I am somewhat familiar with. I discovered an old pretty ratty cork type valve cover casket that was slightly distorted. I decided to look up the John Rogers valve cover modification on Pelican Parts and welded up the side that was leaking. I used a new silicone gasket from 914 rubber. It looks dry so far but I haven't really driven it much since finished. Here's the tech article. A pretty easy mod. that might save ya some grief in the future. http://www.pelicanparts.com/techarticles/9...alve_covers.htm
Elliot Cannon |
Mar 21 2017, 09:03 AM
The stock valve cover only has a small approx. one inch tab to keep the gaskets from distorting inward and allowing leaks. Welding a continuation of that tab completely around the inside of the valve cover prevents the gasket from slipping in. Are you using my link or going directly to the Pelican Parts web site?
Lo-Fi Version | Time is now: 3rd May 2024 - 02:25 AM |
