Just put in LED dash lights, I made the simple hard... |
oakdalecurtis |
Mar 20 2017, 10:07 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Just got eight dash LED bulbs from Super Bright LED's, BA7S-W Cool Whites. I thought I would just pop them in. Not so fast. I tried one new bulb in a center console gauge first. The LED bulb would not go into the plastic bulb fixture quite far enough to turn and lock due to a small metal rim on the bulb. I did not want to file the rim down on the bulb, so I removed the light fixture and filed about a 1/16 of an inch off the top. This would allow the bulb to go in far enough now to turn and lock. Then when I did get the bulb in, it didn't work. I quickly discovered that LED bulbs have a polarity and you must hook up the 2 wire leads in the correct polarity. Ahh, it worked now. I filed down the bulb fixtures on the other 2 console gauges and moved on to the dash gauges. Thankfully the metal bulb fixtures in the dash gauges fit the LED bulbs without needing shortening. Then I started working on the speedometer bulbs. I didn't seat and rotate one of the LED's completely in it's fixture and it fell out INSIDE the speedo! I had to remove the speedo from the dash and spend an hour trying to figure out how to get the LED bulb back out the hole without disassembling the speedo. I finally succeeded and put everything back together. Here's a few before and after pictures, but they don't really show the quality of the improvement in the light. The first picture is original bulbs, the second and third pics are the new LEDs.
whitetwinturbo |
Mar 20 2017, 10:41 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:02 PM |
