Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
SixerJ |
Apr 3 2017, 02:32 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Hi Jeff, 1st off apologies for the delay, work and family has been crazy
Anyway here are the dimensions all in mm, plus a few more in case they help A = 16.1 B = 20.1 C = 32.2 D1 = 42 to centre of hole slot D2 = 46 to centre of M6 hole Looking at the hole I would say the curved radius would match a 20 round hole, simply chop off the sides so it is 16 wide Overall length of welded on U = 25.2 (material thickness 4) Width of U externally at the widest part (open end) = 27 / it does narrow slightly down to 18 internally) Open end of the U is 52 from the end of the column tube U shape maximum depth (sticking out from the tube it is shaped into the curve of the tube at the closed end) = 16 M6 hole from the external corner at the open end of the U (both x and y) = 6 I'll link to this from the left side ignition thread in case it's useful Anything else let me know |
Lo-Fi Version | Time is now: 4th May 2024 - 02:57 PM |
