Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
yellowporky |
Mar 6 2018, 10:01 AM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
Jeff,
I have already removed my ignition switch from the column of my 75 and have not done anything with the cover. 75 is plastic and i did not know that earlier ones were metal. Would you be willing to re-create the cover modification that you did? if so how much. Please pm me Thanks Chris |
Lo-Fi Version | Time is now: 4th May 2024 - 03:21 PM |
