Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
Larmo63 |
Mar 6 2018, 09:41 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
jkb944t |
Mar 6 2018, 12:56 PM
The part that will be difficult with using the 911 steering column is Integrating the electrical connections for the different turn signal and wiper switches. The non-locking 911 ignition switch should be electrically the same as what I am going to be doing. I am not sure how the non-locking 911 ignition switch mounts into the dash. Does it use the same special angled mounting plate or is it just a straight hole though the dash? Jeff B |
Lo-Fi Version | Time is now: 4th May 2024 - 05:06 PM |
