Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
ClayPerrine |
Mar 8 2018, 02:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I moved my emergency flasher on my six conversion when I put in the 911 column and the key on the left. I just cut a long section with the plug out of an old scrap harness and spliced the wires together. Works great on the right.
jkb944t |
Mar 8 2018, 04:10 PM
I moved my emergency flasher on my six conversion when I put in the 911 column and the key on the left. I just cut a long section with the plug out of an old scrap harness and spliced the wires together. Works great on the right. This is exactly what I plan to do. I looked last night at a spare wiring harness I have and the wires I need are in that harness. I’ll just have to get the male and female connectors. Jeff B |
Lo-Fi Version | Time is now: 4th May 2024 - 02:06 PM |
