Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
gothspeed |
Mar 13 2018, 02:31 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
jkb944t if possible post pics when you get the final appearance bezel installed. (IMG:style_emoticons/default/smile.gif)
The plastic ones can be done with epoxy, and a filler piece.. for comparison , here is the one I did (IMG:style_emoticons/default/beerchug.gif) Hmmm I didn't know there were plastic versions of this piece. Mod looks good! |
Lo-Fi Version | Time is now: 4th May 2024 - 03:19 PM |
