Left side ignition switch conversion-Alternate Idea, Conversion is completed. |
jkb944t |
Mar 22 2017, 11:07 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
sixnotfour |
Mar 12 2018, 01:34 PM
914 Wizard Group: Members Posts: 10,420 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The plastic ones can be done with epoxy, and a filler piece..
for comparison , here is the one I did (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
jkb944t |
Mar 13 2018, 03:45 PM
The plastic ones can be done with epoxy, and a filler piece.. for comparison , here is the one I did (IMG:style_emoticons/default/beerchug.gif) The plastic body would certainly make the conversion easier. It looks great! (IMG:style_emoticons/default/beerchug.gif) Jeff B |
Lo-Fi Version | Time is now: 4th May 2024 - 06:34 PM |
