Which Throttle cable do I need?, I need a quality cable, the new one I received fell apart when I opened it. |
Rand |
Mar 23 2017, 07:02 PM
Just to clarify, this isn't about the vendor, it's about the brand of the product. Terrycable is a safe buy.
brant |
Mar 24 2017, 01:44 PM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Just to clarify, this isn't about the vendor, it's about the brand of the product. Terrycable is a safe buy. agreed! I have had only positive experiences from Pelican over years and years... in my case I ordered 2 cables at once. one as maintenance for the race car the 2nd as a back up spare to carry to the race track. I broke one cable installing it thought it was a fluke, and put the 2nd cable on went to the track and after 10 minutes of track time, the cable bound internally and the throttle stuck wide open on track. this cable had 10 minutes of use on it from new. very very bad cables. brant |
bretth |
Mar 24 2017, 02:17 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
A new spare Gemo is sitting in my cars trunk when I bought it. Guess I will toss it in the garbage and get a Terrycable as a spare instead. Thanks for the great info all.
brant |
Mar 24 2017, 03:08 PM
another good option is the original equipment Porsche cable
I bought one after the 2 bad experiences I had ran it all last race season with zero problems |
North Coast Jim |
Mar 24 2017, 05:58 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Just to clarify, this isn't about the vendor, it's about the brand of the product. Terrycable is a safe buy. It is also about the vendor who knowingly or unknowlingly distributes product w/o due diligence for quality or it's intended use. Pelican is fine distributor of products who needs to bolster this area. I still buy from them but am cautious. I made a living off this weak point of distribution. |
mobymutt |
Mar 24 2017, 06:04 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
This thread makes me sad, as the first part I bought for my car was the gemo cable. It seems to work fine, but if I routed it up through the proper hole in the tin, it wasn't flexible enough and would bind. I figured it was just an issue with the carb linkage setup, but maybe it's not.
76-914 |
Mar 24 2017, 06:13 PM
I've found a stock cable just isn't long enough to reach my Tangerine carb linkage which I had to mount on the rear of the carbs to avoid interference with the engine tin (I have the short carb manifolds). I used motorcycle cable and bike housing & ferrels and it's been working great for the past couple years. Very smooth and nice routing due to the custom length. My only fear is what to do if it breaks on a trip...I really need to make a spare. They'll customize the 914 Cable per your request. Just tell them how long/short you want the sheath and/or the cable to be. The std 914cable was just a foot short for the Suby conversion so I asked and they made a 914 cable with a bit longer sheath and the cable was another foot longer. (IMG:style_emoticons/default/beerchug.gif) |
Olympic 914 |
Mar 24 2017, 06:29 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
This thread makes me sad, as the first part I bought for my car was the gemo cable. It seems to work fine, but if I routed it up through the proper hole in the tin, it wasn't flexible enough and would bind. I figured it was just an issue with the carb linkage setup, but maybe it's not. Just had the same thing happen to me. when I installed the cable it was hard to get to feed smoothly through the tin and then the cable came loose at the ferrel (?) at the firewall. and the throttle would not return all the way. I ended up buying another one, that just happened to be a Gemo from someone off of fleabay. it fit good and works much smoother than the other one , that also had zero miles on it. I don't know what brand the old one was. Probably URO. (IMG:style_emoticons/default/happy11.gif) I may have to look into these terry cables |
mark04usa |
Mar 24 2017, 09:08 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
The Italian made Cofle brand cables are very good quality and work well. The Terry cables are heavy duty, but also have a lot more drag due to very thick cable.
Seelenfan |
Mar 25 2017, 08:37 PM
Newbie Group: Members Posts: 38 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
I installed the Terry cable today. Works perfect!!
injunmort |
Mar 25 2017, 08:43 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i have used a cofle and gemo, i see no diff, after 8nyears both wor fine
Lo-Fi Version | Time is now: 26th April 2024 - 09:30 AM |
