Tranny Problem |
Tranny Problem |
kkid |
Mar 23 2017, 12:57 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hello guys,
So my tranny has been acting up since an incident. When the engine is off it shifts in to any gears as it should( I think). But when the motor is on it wants to go to reverse from 1st gear instead of 2nd, as if there is no 2nd. Is my tranny broken? Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
ndfrigi |
Mar 23 2017, 01:34 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hello guys, So my tranny has been acting up since an incident. When the engine is off it shifts in to any gears as it should( I think). But when the motor is on it wants to go to reverse from 1st gear instead of 2nd, as if there is no 2nd. Is my tranny broken? Thanks, kkid (IMG:style_emoticons/default/smile.gif) Probably just bushing(s) from shift linkage. From shift lever to firewall and all the way to transmission. When is the last time sir you replaced or checked them? |
kkid |
Mar 26 2017, 12:42 PM
Hello guys, So my tranny has been acting up since an incident. When the engine is off it shifts in to any gears as it should( I think). But when the motor is on it wants to go to reverse from 1st gear instead of 2nd, as if there is no 2nd. Is my tranny broken? Thanks, kkid (IMG:style_emoticons/default/smile.gif) Probably just bushing(s) from shift linkage. From shift lever to firewall and all the way to transmission. When is the last time sir you replaced or checked them? The bushings are all in good shape. What happened was it actually went into reverse from 1st once when the car is going forward and the car stopped suddenly. Later I found one of the cone set screws(at the shift console) was loose. Then I tighten it up but the shifter does not want to go to 2nd from 1st anymore. kkid (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:21 PM |
