Speedometer cable routing or....., It's a little long |
NJTom |
Mar 24 2017, 03:34 PM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
Those darn "gremlins". OK we are trying to get everything back together and the speedometer cable seems like it's 2 feet to long. See picture ummmm help?
Attached thumbnail(s) |
ejm |
Mar 24 2017, 06:35 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Is the other end of the cable connected to the speedo or something else. There are two different length cables for with or without the EGR counter box which was fitted to later cars. Bumper suggests it's an early car... maybe the cable isn't routed correctly...btw your transmission mount is assembled wrong
NJTom |
Mar 25 2017, 05:58 AM
THNAKS!
stinkindiesel |
Mar 27 2017, 03:13 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Recently went through this as well. In my case, the speedo cable had been routed incorrectly. Since I have a console, the cable was pulled short in the cabin. When I rerouted the cable all the way up to the firewall and then up to the speedo (which would have been obvious if there was no console covering it up), it took out the extra length that had me scratching my head.
Gary |
Asheikh |
Nov 10 2022, 01:14 AM
Newbie Group: Members Posts: 48 Joined: 7-August 15 From: Pakistan Member No.: 19,037 Region Association: Pakistan |
What is the proper route for the speedometer cable ?
bdstone914 |
Nov 10 2022, 09:14 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@NJTom
' The only cable available is the longer one. Does not look like you have a 75-76 car that had the EGR counter box in the passenger footwell. Connect it at the speedo. Route it over the top of the axle and attach it to the top stud on the side plate with a loop clamp. That will keep it away from the heat exchangers. And the cupped washers on the trans washers need to be flipped. The bolts insert from the bottom so you dont have to remove the rubber mounts to drop the trans. |
dr914@autoatlanta.com |
Nov 10 2022, 09:46 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
your transmission mounting cups are upside down by the way
Lo-Fi Version | Time is now: 4th May 2024 - 05:08 AM |
