Speedometer cable routing or....., It's a little long |
NJTom |
Mar 24 2017, 03:34 PM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
Those darn "gremlins". OK we are trying to get everything back together and the speedometer cable seems like it's 2 feet to long. See picture ummmm help?
Attached thumbnail(s) |
bdstone914 |
Nov 10 2022, 09:14 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@NJTom
' The only cable available is the longer one. Does not look like you have a 75-76 car that had the EGR counter box in the passenger footwell. Connect it at the speedo. Route it over the top of the axle and attach it to the top stud on the side plate with a loop clamp. That will keep it away from the heat exchangers. And the cupped washers on the trans washers need to be flipped. The bolts insert from the bottom so you dont have to remove the rubber mounts to drop the trans. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:37 AM |
