Sound deadening on floor. Removal., Any tips would be helpful. |
Seelenfan |
Mar 24 2017, 08:49 PM
Newbie Group: Members Posts: 38 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
Sound deadening on the floor. Anyone have good tips for removing the tar like sound deadening? This is an Arizona car, which means the tar has baked on for 40 years.
iankarr |
Mar 24 2017, 09:02 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hey there. I feel your pain. I also had an AZ car.
Search is your friend. Lots of threads on this. Here's one... http://www.914world.com/bbs2/index.php?showtopic=195442 Basically, a combination of heat, a multi-function tool, and a putty knife are the weapons of choice. |
Seelenfan |
Mar 24 2017, 09:10 PM
Thanks for the link. I tried to search for threads on the site before posting. I'm not sure what I'm doing wrong as I don't ever get any returns from the search.
iankarr |
Mar 24 2017, 09:18 PM
I use google. just include 914world in the search. good luck and welcome!
simonjb |
Mar 24 2017, 09:23 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Heat gun plus a scraper worked wonders
914_teener |
Mar 24 2017, 10:36 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I still have the sound deadening tar in my car.
If the metal underneath is not rusted why take it out? |
Mikey914 |
Mar 24 2017, 10:40 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Shared on my Facebook you gotta see this
https://www.facebook.com/4Piston/videos/1258619500895777/ It's pretty cool Don't try to remove until you have seen this. |
sixaddict |
Mar 25 2017, 03:14 AM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Mark
That is ingenuous! After all the hours with heat gun I am amazed. Was that just water added to dry ice? Thanks |
mepstein |
Mar 25 2017, 07:14 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Shared on my Facebook you gotta see this https://www.facebook.com/4Piston/videos/1258619500895777/ It's pretty cool Don't try to remove until you have seen this. You threw a 7-11 slurpee on it. Great trick! |
defianty |
Mar 25 2017, 07:42 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Costa05 |
Mar 25 2017, 03:38 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Mikey914 |
Mar 25 2017, 04:14 PM
I've been dying to try this just don't need to at the time.
Post up your results please. |
Mark Henry |
Mar 25 2017, 04:37 PM
Calwaterbear |
Mar 26 2017, 01:11 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
OK guys, I just got done trying this. The video was a bit short on details, I used 9 lbs of dry ice, and 1 quart of 70% isopropyl alcohol. I crushed up the ice using the head of a hammer. made the slush, just like in the video.
Put it in one of the 4 sections of the floor panel. after letting it sit for 5 minutes, went in with a putty knife. Pretty soon after that, started using a hammer on the putty knife. long story short, it was pretty much the same thing using the dry ice technique, as just brute forcing the other side with just a putty knife and a hammer. Given it cost me 20 bucks for materials, and it didn't save any time or effort - for me and my 72 - it was a bust. The issue seems to be that the material is just pretty much tar at this point, and it really adheres to the metal. anywhere there was a crack in the liner, you could count on finding rust underneath that spot. Back to the heatgun. What a disappointment! |
funk |
Mar 26 2017, 02:48 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
snap on makes a great tool for removing all seam sealer and I am certain it would remove that stuff as well!!
Localboy808 |
Mar 26 2017, 05:41 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
Calwaterbear |
Mar 26 2017, 05:57 PM
You are probably right, but I had the floor board covered with 2 inches of slush, and it sat there for over 1/2 an hour, as I tried to scrape off portions.
Not sure what I did wrong. I was just reporting that it did not work for me! |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:33 PM |
