FS Front Sway Bar, 19mm New hardware, used bar $350 |
bdstone914 |
Mar 25 2017, 08:10 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The sway bar levers and installation hardware are new from about the 80's. Has original yellow faded instructions from H & H. Had to make one top block for a lever, then had them powder coated. Includes hardware to install triangle mounts into the body. Requires cutting and metal work skills. That means if you do not know what you are doing don't try and screw it up.
Bar is a 19mm and in good used shape. Paint worn on the ends. The longer levers give the 19mm bar a setting that is closer to the original 15mm bar, if used on the farthest out setting. New sway bar drop link bushings will be bought and included. $350 plus shipping which runs about $25 in the U.S. Will ship worldwide at cost. Bruce Attached thumbnail(s) |
bdstone914 |
Mar 27 2017, 10:13 PM
bump for picture added
Lo-Fi Version | Time is now: 5th May 2024 - 03:31 AM |
