This can't be good., rocker movement - help diagnosing before tearing |
iankarr |
Mar 26 2017, 09:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in. OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing. Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve? From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses.... Thanks! |
r_towle |
Mar 26 2017, 10:53 AM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Have you considered you may have hydraulic lifters?
Let it warm up, a lot. When sitting for a long period all the oil will drain out of the lifter and it takes 5-10 minutes to fill them up so the noise level goes down. If you have concerns, pull that rocker set, pull the rod and tube, get a magnet and pull the lifter to take a look. That can be done with the motor in place....some of them you cannot totally remove the tube but you done need to |
stugray |
Mar 26 2017, 11:01 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
....some of them you cannot totally remove the tube but you done need to I used to believe that until DaveDarling straightened me out. If you pop the tube loose and remove the outer seal, you can pull the tube out of the head towards the engine. They do not have to come out towards the outside of the car where some will hit the suspension ear before coming clear. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:04 AM |
