This can't be good., rocker movement - help diagnosing before tearing |
iankarr |
Mar 26 2017, 09:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in. OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing. Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve? From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses.... Thanks! |
Mark Henry |
Mar 27 2017, 12:03 AM
You absolutely have to change the cam to go to solid lifters.
Looking at the pushrods and lifter I can tell you I'm 99.9 % sure that it's an aftermarket hydraulic setup. The .01 % is it could be a stock VW hydraulic cam with aftermarket lifters and PR's. The solid steel spacer on the rocker shaft are stock VW hydraulic, keep them. With the correct number of rocker shaft flat (thick) washers you can use them for T4 performance with 911 swivel feet, big cam, etc. Don't use the thin wave washers like in the pic for this, as they will break. In fact I prefer steel spacers and consider the aftermarket aluminum spacers as cheap crap, because they wear too fast. CrMO for sure... Never say "for sure", I would bet it's just cheap regular steel pushrods, not CrMo. QUOTE Cam any ones guess. I"d go to solid lifter. Or is that injecting another problem? Yes, it would be creating another problem. All hydraulic lifters have hydraulic only cam grinds, even the so called performance hydraulic cams. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:17 AM |
