This can't be good., rocker movement - help diagnosing before tearing |
iankarr |
Mar 26 2017, 09:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in. OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing. Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve? From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses.... Thanks! |
rgalla9146 |
Mar 26 2017, 02:28 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Maybe it's just that one ?.....best to check .... remove all rocker shafts and pushrods (as many as possible easily) not the return tubes just yet.
Buy or borrow a boroscope and check each lifter. |
Lo-Fi Version | Time is now: 9th May 2024 - 09:52 PM |
