This can't be good., rocker movement - help diagnosing before tearing |
iankarr |
Mar 26 2017, 09:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in. OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing. Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve? From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses.... Thanks! |
r_towle |
Mar 26 2017, 05:16 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It could be fine if you let the oil get warm and fill up all the lifters again. No damage will happen, just lots of noise till the valves get warm.
If you want to check the cam, pull the oil pump and look for rivets instead of bolts where the cam is fastened to the cam gear. Stock is rivets. |
Lo-Fi Version | Time is now: 9th May 2024 - 06:53 PM |
