Newbie Introduction, Introduction |
Seelenfan |
Mar 26 2017, 02:11 PM
Newbie Group: Members Posts: 38 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
I have been lurking around the site for a while and even purchased a few items from other members. I purchased my basket case project about two months ago. It has a 1.7L, it is an AZ car with little to no rust. Every piece of rubber and plastic is dry, split or missing. Since owning it I have done the following:
-Rebuilt progressive carb, -Dissasembled​ and cleaned distributor -New points, condenser, cap rotor, wires, plugs and coil. -Replaced the electric fuel pump -Removed and flushed fuel tank -Installed new fuel line -Replaced throttle cable -Removed inspected, cleaned and relived pedal assembly. -Replaced front wheel bearings -Rebuilt front calipers, re assembled brakes with new pads -Bled brake lines. -Set valves -Added case vents (back to the carb) -I got the motor running, ideling well. And I drove it around the block yesterday. I'm going to spend all summer collecting parts. |
krazykonrad |
Mar 26 2017, 06:43 PM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
It doesn't look that bad. It could use some paint, but it's not the worst one on here by far. Keep asking questions. The beauty of this site is that at least one person will have the answer to your question. I've been asking dumb questions on here for the last 11 years and they still keep me around.
(IMG:style_emoticons/default/welcome.png) Konrad |
Lo-Fi Version | Time is now: 17th May 2024 - 12:24 AM |
