Newbie Introduction, Introduction |
Seelenfan |
Mar 26 2017, 02:11 PM
Newbie Group: Members Posts: 38 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
I have been lurking around the site for a while and even purchased a few items from other members. I purchased my basket case project about two months ago. It has a 1.7L, it is an AZ car with little to no rust. Every piece of rubber and plastic is dry, split or missing. Since owning it I have done the following:
-Rebuilt progressive carb, -Dissasembled​ and cleaned distributor -New points, condenser, cap rotor, wires, plugs and coil. -Replaced the electric fuel pump -Removed and flushed fuel tank -Installed new fuel line -Replaced throttle cable -Removed inspected, cleaned and relived pedal assembly. -Replaced front wheel bearings -Rebuilt front calipers, re assembled brakes with new pads -Bled brake lines. -Set valves -Added case vents (back to the carb) -I got the motor running, ideling well. And I drove it around the block yesterday. I'm going to spend all summer collecting parts. |
tom.esh |
Mar 26 2017, 07:29 PM
Member Group: Members Posts: 62 Joined: 6-March 14 From: Canton Ohio Member No.: 17,083 Region Association: North East States |
Welcome, at least yours is drivable. Better shape than mine.
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 PM |
