Newbie Introduction, Introduction |
Seelenfan |
Mar 26 2017, 02:11 PM
Newbie Group: Members Posts: 38 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
I have been lurking around the site for a while and even purchased a few items from other members. I purchased my basket case project about two months ago. It has a 1.7L, it is an AZ car with little to no rust. Every piece of rubber and plastic is dry, split or missing. Since owning it I have done the following:
-Rebuilt progressive carb, -Dissasembled​ and cleaned distributor -New points, condenser, cap rotor, wires, plugs and coil. -Replaced the electric fuel pump -Removed and flushed fuel tank -Installed new fuel line -Replaced throttle cable -Removed inspected, cleaned and relived pedal assembly. -Replaced front wheel bearings -Rebuilt front calipers, re assembled brakes with new pads -Bled brake lines. -Set valves -Added case vents (back to the carb) -I got the motor running, ideling well. And I drove it around the block yesterday. I'm going to spend all summer collecting parts. |
Seelenfan |
Mar 26 2017, 08:34 PM
Thanks for the warm welcome. And yes I have been all over the 914rubber website. As for the body, I could strip it fix the dents and leave it bare metal for a while. Here in AZ this can be done. It's a dry heat :-)
McLovin |
Mar 26 2017, 09:22 PM
Member Group: Members Posts: 102 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 PM |
