1975 Fuel Tank Removal |
frankiec@outrageous.net |
Mar 26 2017, 03:00 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
driftingcloud |
Mar 26 2017, 03:13 PM
Die welt ist flach... Group: Members Posts: 39 Joined: 9-January 15 From: Asheville, NC Member No.: 18,310 Region Association: South East States |
This is absolutely no help to your question, but gorgeous car. I'm working on a bumper back-date and side marker removal to my '75 as well.
JeffBowlsby |
Mar 26 2017, 07:16 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If your 75 is stock there is an access panel in the trunk bulkhead to access the pump and filter. No need to pull the tank.
bigkensteele |
Mar 26 2017, 07:24 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
If your 75 is stock there is an access panel in the trunk bulkhead to access the pump and filter. No need to pull the tank. (IMG:style_emoticons/default/agree.gif) unless your soft lines are old. If they are toast, I would pull the tank. It is not a difficult job, but much easier with two people. Order the Haynes manual. It is a wealth of information. I would also recommend learning to master the search function on this site. Before you order a new filter, pull the access panel on the bulkhead, and determine which filter you need. There are two versions - one with identical in/out nipples and one with larger/smaller. My '75 takes the large/small. If you still have the plastic fuel lines in the center tunnel, I would go ahead a replace every line, stem to stern. |
Tjmrfe |
Mar 26 2017, 07:30 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
I may have to replace my fuel filter on my 75 914. Is there any source with a detailed description of removing the tank, especially with pics. Any help greatly appreciated. Thanks, Tom I just replaced my fuel filter in my 75... it was tucked behind the fuel,pump near access panel behind spare....pain in the tookus to remove, but fuel tank stayed in its place.... I invested in fuel line clamps, to prevent fuel from leaking out of lines, made it easier than vise grips...good luck. |
ljubodraz |
Mar 26 2017, 07:44 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
What all others have said is very correct. Check on the type of existing filter first. I thought Pelican sent the wrong filter for my '75 until I checked. Previous owners can make many changes. It was a real pain to get it all tucked back in. I kinked a fuel line on my first few attempts.
Look between tank bulkhead and spare tire per attached photo. Sorry. First time trying to post a pic from iPhone. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:22 PM |
