1975 Fuel Tank Removal |
frankiec@outrageous.net |
Mar 26 2017, 03:00 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
JeffBowlsby |
Mar 26 2017, 07:16 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If your 75 is stock there is an access panel in the trunk bulkhead to access the pump and filter. No need to pull the tank.
bigkensteele |
Mar 26 2017, 07:24 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
If your 75 is stock there is an access panel in the trunk bulkhead to access the pump and filter. No need to pull the tank. (IMG:style_emoticons/default/agree.gif) unless your soft lines are old. If they are toast, I would pull the tank. It is not a difficult job, but much easier with two people. Order the Haynes manual. It is a wealth of information. I would also recommend learning to master the search function on this site. Before you order a new filter, pull the access panel on the bulkhead, and determine which filter you need. There are two versions - one with identical in/out nipples and one with larger/smaller. My '75 takes the large/small. If you still have the plastic fuel lines in the center tunnel, I would go ahead a replace every line, stem to stern. |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:16 AM |
