Remote Oil Cooler Options, Can you show me some of your installs and what coolers you used. |
NS914 |
Mar 27 2017, 11:44 AM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hi Everyone,
I just finished up my Oil Return tubes and strainer etc and got to thinking about a remote mount oil cooler...not that I really need it for the most part living in Nova Scotia but its one of those while I have the engine out thoughts. I have been looking at Cooler and with our Cdn dollar being what it is and the general cost anyway, I was hoping the community could suggest show us some of the set ups you have already gone with. I have a 2 litre with weber carbs not that is matters but just for some background Much thanks as always! Grant |
Dave_Darling |
Mar 27 2017, 12:14 PM
Do you need a cooler? If not, it is a waste to install one.
Do you want to cut the car up? How many holes can you live with? Options include: - Under the engine lid. This is very easy to mount and set up. It can cause odd readings from your dipstick as the oil in it drains back into the crankcase, and you will have to lose the rain tray. It also preheats your cooling and your induction air to some extent, which is not necessarily optimal. - Under the rear trunk floor. This is moderately easy to set up, depending on exactly where you run the lines and so forth. Generally the only holes needed are mounting holes for the brackets. Oil hose routing can be a bit complicated, and it can make access to the valve covers or other components more difficult. This is also the least effective location, as it does not get a good supply of cold clean air. Even with a fan, it's not great. - In the front trunk, with a ducted enclosure. This is the most effective location, as you get cold and clean air, and it is forced through the cooler. Generally exit is out the bottom of the front trunk floor. This requires cutting the tub to get air in and out again, and relatively long oil lines and quite a few holes for them. All of the above work to some extent. They have all been shown to reduce oil temps that are too high. They are different amounts of work, and different costs for each setup. I have a cooler under the rear trunk floor, and am happy enough with it. I did not want to cut the tub or deal with the lines up on top of the engine, so I picked my compromise. There are also less-common setups, most of which place the cooler potentially in harm's way. (E.g., under the front bumper, in front of the front bumper, flat against the front trunk floor, inside the wheel well, etc.) All have their own compromises, as well, but there is a reason these are not as common. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 12:19 PM |
