Clutch Tube Repair, Tube/Firewall side |
914 |
Mar 28 2017, 08:49 AM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
Looking at my "4" yesterday while at the shop a previous repair was done to the tube and firewall area.. Isn't the tube supposed to protrude out of the back of the firewall like the throttle cable does ? So is my case the clutch cable is loose on to the firewall..
My question is how much tube should be extending out of the firewall ? On the clutch adjustment there are about 1.5"+ of spacer washers there..To repair it can a smaller diameter tube inserted in the existing tube a welded on,as only the cable goes thru that area? I still have to Ck the tube connection points it the tunnel.. Thanks for all the help.. Alan/ 914[attachmentid= 598493] |
IronHillRestorations |
Mar 28 2017, 11:29 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
For starters, clean off all the oogie on the firewall first, then move the metal back as close as possible to the original location.
Ideally you cut open an access panel in the center tunnel to repair the strap on the tube. Next fabricate a plate to reinforce the firewall and give you something to re-weld the tube to. At one time there was someone selling repair pieces on eBay, but I haven't seen those in a while. After that you may look at rebuilding the pedal cluster. From my experience fixing the tube will put stress on the clutch pedal roll pin, and if it's not in good shape it will shear |
Lo-Fi Version | Time is now: 20th May 2024 - 12:52 AM |
