another electrical issue, dim bulb - not me |
JimN73 |
Mar 30 2017, 03:31 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
The turn signal indicator lights in the dash are really dim. I changed the bulbs but there is no improvement.
The contacts at the bulb are good. Where else should I look? it's a '73 Thanks. |
76-914 |
Mar 30 2017, 05:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Seelenfan |
Mar 31 2017, 09:56 AM
Newbie Group: Members Posts: 41 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
Check the ground wires for that circuit. I have seen this happen on other brands cars on headlights. It ended up being a poor ground. |
porschetub |
Mar 31 2017, 01:26 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
What voltage do you have @ the lamp holder ?.
I deleted my dimmer system and went to LED's will never go back,original lamps provide marginal backlighting. |
Mikey914 |
Mar 31 2017, 03:18 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
LEDs operate on a fraction of the current. They are somewhat dimable.the while make the gages look much better at night.
I have them if you need them. Mark |
JimN73 |
Mar 31 2017, 06:02 PM
LEDs operate on a fraction of the current. They are somewhat dimable.the while make the gages look much better at night. I have them if you need them. Mark Thanks, Mark. I changed the gauge lights to your LEDs already. The turn signal lights in the tach are the current problem. I understand that the flasher interferes with LEDs in this case. |
914GT |
Mar 31 2017, 07:09 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Are you sure it is the bulb? The colored plastic gels in the gauge darken over the years and need to be replaced.
JimN73 |
Mar 31 2017, 10:10 PM
Mikey914 |
Apr 1 2017, 09:07 AM
Bulb or bulb holder? I can send another bulb if there is a problem.
Mark |
Spoke |
Apr 1 2017, 09:23 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Do both indicators flash at the same time?
Are they brighter with the 4-way flasher on? |
porschetub |
Apr 2 2017, 02:12 PM
Oh ok,OP didn't mention LED's.
JimN73 |
Apr 3 2017, 09:40 AM
Lo-Fi Version | Time is now: 2nd June 2024 - 05:21 PM |
