The turn signal indicator lights in the dash are really dim. I changed the bulbs but there is no improvement.
The contacts at the bulb are good. Where else should I look? it's a '73
Thanks.
76-914
Mar 30 2017, 05:34 PM
Seelenfan
Mar 31 2017, 09:56 AM
QUOTE(76-914 @ Mar 30 2017, 06:34 PM)
Check the ground wires for that circuit. I have seen this happen on other brands cars on headlights. It ended up being a poor ground.
porschetub
Mar 31 2017, 01:26 PM
What voltage do you have @ the lamp holder ?. I deleted my dimmer system and went to LED's will never go back,original lamps provide marginal backlighting.
Mikey914
Mar 31 2017, 03:18 PM
LEDs operate on a fraction of the current. They are somewhat dimable.the while make the gages look much better at night. I have them if you need them. Mark
JimN73
Mar 31 2017, 06:02 PM
QUOTE(Mikey914 @ Mar 31 2017, 02:18 PM)
Thanks, Mark. I changed the gauge lights to your LEDs already. The turn signal lights in the tach are the current problem.
I understand that the flasher interferes with LEDs in this case.
914GT
Mar 31 2017, 07:09 PM
Are you sure it is the bulb? The colored plastic gels in the gauge darken over the years and need to be replaced.
JimN73
Mar 31 2017, 10:10 PM
QUOTE(914GT @ Mar 31 2017, 06:09 PM)
It's the bulb, Guy. So dim.
Mikey914
Apr 1 2017, 09:07 AM
Bulb or bulb holder? I can send another bulb if there is a problem. Mark
Spoke
Apr 1 2017, 09:23 AM
Do both indicators flash at the same time?
Are they brighter with the 4-way flasher on?
porschetub
Apr 2 2017, 02:12 PM
Oh ok,OP didn't mention LED's.
JimN73
Apr 3 2017, 09:40 AM
Thanks, Mark. I have some new regular bulbs, put them in and there is an improvement.
