Gearbox input shaft seal installation? |
falcor75 |
Apr 1 2017, 07:51 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
How deep should it be installed? Flush with the outer flange or flush with the inner flanfe??
BeatNavy |
Apr 1 2017, 10:11 AM
The primary goal is to just get the seal deep enough so that it doesn't interfere with the tube when mounted back onto the case. The way you check that: if the seal's opening starts to distort at any point while you're installing that tube, the seal needs to go deeper. If it does not distort, and the tube mounts cleanly then, in the words of Dr. Evil "you're golden, be happy."
Stock seals had a shoulder that sat on the lip of the opening, but most replacements do not, I believe. |
Lo-Fi Version | Time is now: 24th May 2024 - 11:00 PM |
