Jacking up rear of 914. |
Keith914 |
Apr 1 2017, 05:37 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Is it acceptable to place a jack under the rear end of the transmission to raise the rear of the car? We do it with no problems similarly by placing a jack under the engine of 911's near the rear end of the engine case to raise the rear of the whole car.
injunmort |
Apr 1 2017, 05:45 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
it is frowned upon, but i will jack in the middle of the trans on the webs
Cracker |
Apr 1 2017, 08:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I wouldn't do it anywhere on the trans...it places all the pressure on the trans mount bushings. JMHO
Tony |
Tom_T |
Apr 1 2017, 09:11 PM
I wouldn't do it anywhere on the trans...it places all the pressure on the trans mount bushings. JMHO Tony (IMG:style_emoticons/default/agree.gif) .... & then your bushings are holding 1/2 the weight of the car +/- 1100 lbs., instead of just the few 100 lbs. transaxle. Better to jack at one of the rear jack doughnuts, or at the middle cross-section between them. There is a pic of them which has been posted, but it was saved on my old laptop, so maybe someone else can post that pic of the safe 914 jacking points for you? (IMG:style_emoticons/default/confused24.gif) Be Safe! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
injunmort |
Apr 1 2017, 10:43 PM
as i said, it, frowned upon, but, it does not twist anything. not optimimum, but with one jack, easiest way to get it up on stands, if it really stresse the mounts, they need to be replaced anyway.
Apr 1 2017, 11:55 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
as i said, it, frowned upon, but, it does not twist anything. not optimimum, but with one jack, easiest way to get it up on stands, if it really stresse the mounts, they need to be replaced anyway. I strongly disagree. The stock mounts and many of the aftermarket mounts are rubber based. Normally, they only have to support half the weight of the transmission and engine pulling down on them. If you use the transmission to jack up the car, you are now putting half the weight of the car on those rubber mounts! (IMG:style_emoticons/default/blink.gif) |
Keith914 |
Apr 2 2017, 08:20 AM
So, I am using a compromise: one jack on each lifting doughnut with two ratchet jacks touching with some of the load under each side of the engine cross bar for safety. Allows access to the two trailing arms for bush replacements.
Thanks for all your advice. |
TheCabinetmaker |
Apr 2 2017, 08:30 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh oh. You said ratchet jack stands. Wait for it!
Cracker |
Apr 2 2017, 09:29 AM
If I am lifting the car to place stands on the rear donuts...I first lift at the engine mount/cross-bar. Easy and strong + no bushings to stress.
T |
TheCabinetmaker |
Apr 2 2017, 09:42 AM
Not as strong as you might think. The mount bar is bolted to a small piece of metal than can and does bend. Not meant to hold the weight of the car, just the engine.
Cracker |
Apr 2 2017, 09:48 AM
In all fairness, mine is 1" thick but have never experienced any deflection before with 1/4" plate. Still better than lifting at the trans...
T Not as strong as you might think. The mount bar is bolted to a small piece of metal than can and does bend. Not meant to hold the weight of the car, just the engine. |
theleschyouknow |
Apr 2 2017, 10:23 AM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
I wouldn't do it anywhere on the trans...it places all the pressure on the trans mount bushings. JMHO Tony (IMG:style_emoticons/default/agree.gif) .... & then your bushings are holding 1/2 the weight of the car +/- 1100 lbs., instead of just the few 100 lbs. transaxle. Better to jack at one of the rear jack doughnuts, or at the middle cross-section between them. There is a pic of them which has been posted, but it was saved on my old laptop, so maybe someone else can post that pic of the safe 914 jacking points for you? (IMG:style_emoticons/default/confused24.gif) Be Safe! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Tom, you mean this one? I jack it up by the engine mount cross-bar & then place jack stands under the donuts interesting observation by Kurt on the strength of the cross-bar attachment I may need to modify the way I do it. I only lift by the bar I don't use it as long term support (IMG:style_emoticons/default/beerchug.gif) cjl |
Keith914 |
Apr 2 2017, 10:50 AM
Hmmm! All these comments suggest if you want to get jack stands under the rear doughnut, the jacking point is just in front of the rear doughnuts on the body beams/channels "longs" (?)
Apr 2 2017, 10:52 AM
I first lift at the engine mount/cross-bar. Easy and strong + no bushings to stress. Also worth mentioning that early cars have rubber outer mounts on the engine cross bar! Only the later cars with sideshifter transmission have solid outer mounts. (IMG:style_emoticons/default/shades.gif) |
Cracker |
Apr 2 2017, 10:56 AM
Details, details, details...just get a couple buddies and lift the damn thing up on the stands! (IMG:style_emoticons/default/shades.gif)
T I first lift at the engine mount/cross-bar. Easy and strong + no bushings to stress. Also worth mentioning that early cars have rubber outer mounts on the engine cross bar! Only the later cars with sideshifter transmission have solid outer mounts. (IMG:style_emoticons/default/shades.gif) |
stugray |
Apr 2 2017, 11:00 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
If I want to jack the rear of the car to put jackstands under the rear donuts, I jack the car up using the trailing arm tube, OR I jack using the donut and put the jackstand under the tube.
Now that was all before I started usning a single jack point for the whole rear of the car, but if you want it to NOT put a strain on the trans, then you get solid rear mounts AND build one of these: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1491152451.1.jpg) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:22 PM |
