QUOTE(injunmort @ Apr 1 2017, 09:43 PM)
as i said, it, frowned upon, but, it does not twist anything. not optimimum, but with one jack, easiest way to get it up on stands, if it really stresse the mounts, they need to be replaced anyway.
I strongly disagree. The stock mounts and many of the aftermarket mounts are rubber based.
Normally, they only have to support half the weight of the transmission and engine pulling down on them.
If you use the transmission to jack up the car, you are now putting half the weight of the car on those rubber mounts!
