| branston |
Apr 1 2017, 07:47 PM
Member ![]() ![]() Group: Members Posts: 91 Joined: 17-October 12 From: Lock Haven, PA Member No.: 15,053 Region Association: Upper MidWest |
The blower in the front of my '74 914 now works! - what makes the one in the engine compartment run?
advise appreciated thx. |
| GeorgeRud |
Apr 1 2017, 07:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Pulling up on the red heater control lever on the center console should activate it.
| branston |
Apr 2 2017, 09:37 AM
| PanelBilly |
Apr 2 2017, 10:29 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,952 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
There's an electrical connection on the lever that closes when it's all the way up. Pull yours out and you'll see it.
| oakdalecurtis |
Apr 2 2017, 11:27 AM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
There's an electrical connection on the lever that closes when it's all the way up. Pull yours out and you'll see it. You'll have a hard time pulling the lever out to check the electrical connection if you don't first detach the cables under the car that run to the two heater valves. |
| 914_teener |
Apr 2 2017, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There's an electrical connection on the lever that closes when it's all the way up. Pull yours out and you'll see it. You'll have a hard time pulling the lever out to check the electrical connection if you don't first detach the cables under the car that run to the two heater valves. (IMG:style_emoticons/default/confused24.gif) The heater lever with the red know in the console can come out without touching the heater flapper box cables. The is a spade connector on the heater lever that grounds the relay. |
| Mark Henry |
Apr 2 2017, 11:53 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Yes just pull the cover to confirm that you still have the switch and it's hooked up to a wire. IIRC the switch just grounds out the wire to complete the circuit.
There will also be a fuse I believe (educated guess) on the relay board supplying power to the fan. |
| Rand |
Apr 2 2017, 12:04 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
There's an electrical connection on the lever that closes when it's all the way up. Pull yours out and you'll see it. You'll have a hard time pulling the lever out to check the electrical connection if you don't first detach the cables under the car that run to the two heater valves. Before pulling anything apart, confirm that you are indeed moving the lever all the way to the end of it's throw. The electrical connection happens at the very end. |
| einic |
Apr 2 2017, 12:30 PM
Newbie ![]() Group: Members Posts: 49 Joined: 28-May 10 From: Norway Member No.: 11,773 Region Association: Scandinavia |
Same fuse as fuel pump. On relay board in engine compartment. You can lift the lever up to check electric spade connection without loosening heater cables. Just done it repairing clutch tube.
| branston |
Apr 2 2017, 01:45 PM
Thanks I can't be pulling it up far enough, i have the same issue in my 912e. Duh
Lo-Fi Version | Time is now: 14th April 2026 - 03:06 PM |
