| Eric_Shea |
Apr 4 2017, 10:30 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
First - Hydrolock - I always put the car in 5th gear and push it backward. (IMG:style_emoticons/default/huh.gif)
Second - Time for a rebuild. |
| jeffdon |
Apr 4 2017, 10:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I do not think I hydrolocked it. It was not starting due to a weak battery, pretty sure. I think its a case of rusted rings/cylinders. Soaking with diesel, and tapping the pistons with a block and mallet (not too hard). I have about 3 mm of seperation between the cylinders and case. trying not to pry too much or too hard.
| jeffdon |
Apr 4 2017, 12:13 PM
Just coaxed what I thought was the worst one off. They all seem to be stubborn.
| jeffdon |
Apr 4 2017, 02:15 PM
one to go....
| Puebloswatcop |
Apr 4 2017, 03:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,702 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
| jeffdon |
Apr 4 2017, 03:30 PM
All off. Phew.
| Puebloswatcop |
Apr 4 2017, 03:33 PM
What size engine is it? I might be able to help you out parts wise...for I too know what it is like to be on a tight budget...
| jeffdon |
Apr 4 2017, 03:51 PM
| Puebloswatcop |
Apr 4 2017, 04:12 PM
What size engine is it? I might be able to help you out parts wise...for I too know what it is like to be on a tight budget... 2056. 96mm cylinders and pistons Sorry, I have no 2056 parts. In fact am saving for the same. Just thought if it was a stock size I might be able to help you out. I know I just bought a 73 with the same issue. Anyway, good luck and holler if ya need anything. Still have some spare parts that might help you out at some point. |
| jeffdon |
Apr 4 2017, 04:35 PM
What size engine is it? I might be able to help you out parts wise...for I too know what it is like to be on a tight budget... 2056. 96mm cylinders and pistons Sorry, I have no 2056 parts. In fact am saving for the same. Just thought if it was a stock size I might be able to help you out. I know I just bought a 73 with the same issue. Anyway, good luck and holler if ya need anything. Still have some spare parts that might help you out at some point. Thanks for offering. I got a stock set of jugs. If the rusty ones are too far gone, I can have them bored. So far, only one of the cylinders looks like its got pitting. Hopping its not so far gone as to be beyond honing out. The rings, however, seem to be rusted into the grooves. Gonna give them a long diesel soak. The generosity of 914 people never fails to amaze me. Sniff. Must have dust in my eye all of a sudden. |
| markhoward |
Apr 4 2017, 04:44 PM
Member ![]() ![]() Group: Members Posts: 406 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California
Anybody out there know if its fine to use an ultrasonic cleaner to loosen up the crud? Thought it might help to get things clean after lots of oil soaking. Don't think its a good idea to go very long with ultrasonic part on but the 125 degree dawn water should help loosen things.
| jeffdon |
Apr 4 2017, 04:53 PM
Anybody out there know if its fine to use an ultrasonic cleaner to loosen up the crud? Thought it might help to get things clean after lots of oil soaking. Don't think its a good idea to go very long with ultrasonic part on but the 125 degree dawn water should help loosen things. Got an ultrasonic cleaner? |
| markhoward |
Apr 4 2017, 04:58 PM
sure do. used on my 911 engine build and several greasy things since.
| jeffdon |
Apr 4 2017, 05:06 PM
| iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Glad you got them all off!
I have a used set of 96mm pistons that I can give you. They would need some cleaning up and new rings. I also have 2 usable jugs. Pm me if you want em.... |
| jeffdon |
Apr 5 2017, 09:19 AM
And now to get the frozen rings off..... (IMG:style_emoticons/default/headbang.gif)
| jeffdon |
Apr 5 2017, 09:48 AM
Gotta a question on re-assembling, and what will also need replacing. I am not splitting the case, but I did pull the flywheel.
Stuff I know will need replacing - Cylinder shims (buggered them in teardown) Flywheel lock plate. CV joint gaskets Scnorr washers for CV's Rocker cover gaskets Stuff I am wondering if it can be reused: Main seal O-ring on flywheel I think my push rod tube seals will be fine. Anything else I should be shopping for? |
| iankarr |
Apr 5 2017, 10:14 AM
Since you'll have everything apart, I'd be inclined to replace all seals. Cheap insurance. You can buy a kit that has everything.
http://www.autoatlanta.com/Porsche-Victor-...R039198009.html Not that Im a fan of AA, but theirs was the easiest link to find. And the price isn't bad. Hopefully the water / rust didn't make it down to the crank. Once you have the pistons out, you can look inside and see if you need to split the case. If all looks clean and you don't see any signs of rust or oil leaking around the main seals, you could probably leave those as is. But like I said, cheap peace of mind to replace now. Just my .02... |
| jeffdon |
Apr 5 2017, 10:23 AM
Since you'll have everything apart, I'd be inclined to replace all seals. Cheap insurance. You can buy a kit that has everything. http://www.autoatlanta.com/Porsche-Victor-...R039198009.html Not that Im a fan of AA, but theirs was the easiest link to find. And the price isn't bad. Hopefully the water / rust didn't make it down to the crank. Once you have the pistons out, you can look inside and see if you need to split the case. If all looks clean and you don't see any signs of rust or oil leaking around the main seals, you could probably leave those as is. But like I said, cheap peace of mind to replace now. Just my .02... Good point. Looks ok inside. Some gunk, but I think i will flush it out with a few cans of carb cleaner and call it good. |
| injunmort |
Apr 5 2017, 06:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
you have the engine torn down that far and your going to reuse pushrod tube seals, crank seal and rear seal. renz gasket kit is about $.40.00, front and rearseal about $30.00. i would
seriously rethink that plan, fwiw. you know the old saying, "never the time or money to do it right, always the time to do it twice. jest sayin' |
Lo-Fi Version | Time is now: 1st May 2026 - 07:23 AM |
