> leaky fuel rail screw, does this need a gasket? [Edit: YES!]
914 RZ-1
post Apr 2 2017, 06:43 PM
Porsche Padawan
The screw on the fuel rail appears top be leaking. Not spraying gas everywhere, but a very small "seeping". It's screwed on tight and has a regular metal washer. Does it need a gasket of some sort?
I noticed the PET calls for a "sealing ring", not a washer. NA at Pelican and no part number for just the sealing ring.
Will my FLAPS have a gas-proof washer I could use?
I think I may have answered my question. Found this on TheSamba:
The Aluminum Crush washer is 4 mm diameter and not copper.
and is available from www.pelicanparts.com if you can't find one
in a hardware store.[/quote]
Pelican Prt# 4x8x1-AL-M131. Hex head washer for the fuel pressure testing tap.
Link
4x8x1-AL-M131
Hexagon-Head Bolt With Sealing Ring M 4 X 8. Prt # N0901961
Mikey914
post Apr 3 2017, 09:52 AM
The rubber man
You can use an aluminum washer as it will crush down. I do suspect that a stainless one would work also, but I haven't tried that.
Mark
- Lo-Fi Version Time is now: 25th September 2026 - 04:55 PM
