a914luvr |
Member ![]() ![]() Group: Members Posts: 313 Joined: 6-February 03 From: Riverside, CA Member No.: 259 ![]() |
I just picked up a really nice, low milage 914-6 and was pleasantly surprised to find that it has OEM sway bars on it. I'm wondering if anyone knows if the factory shipped any 914-6's with sway bars or were they installed at the dealerships or ??
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,292 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
If you are going for OE concourse install there is NO welding done in the tank cavity. The (mount) plates were spot welded only inside the wheel wells.
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
If you are going for OE concourse install there is NO welding done in the tank cavity. The (mount) plates were spot welded only inside the wheel wells. yep. thats right. there is an outer plate for the sway bar mount that bolts to factory reinforcing plate. top two bolts had nuts where accessible from tank cavity. bottom bolt on the triangular shape goes into a formed thread that is part of the mount area sheetmetal in the wheel well. pretty sure that is how it goes. at least that is what i can see on mine. the bottom bolt is inaccessible from the tank side. all done at the factory when the body was fabricated. not done at a later stage in assembly. cars built to order with the sway bars. |
Lo-Fi Version | Time is now: 30th June 2025 - 07:22 PM |
