Rustoration time, Help please |
AndyC |
May 7 2005, 09:02 AM
Bend over and empty your wallet Group: Members Posts: 134 Joined: 14-January 05 From: Rugby,UK Member No.: 3,445 |
I have started down the long and lonely road of rustoration (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Just started attacking the windscreen frame as it appears to be the worst part on the car (even the hell hole look better) and this is what I have discovered. Beyond the pitting it all seems quite solid so what is the best way to tackle this for good, if there is such a thing One: Attached image(s) |
AndyC |
May 7 2005, 09:03 AM
two
Attached image(s) |
AndyC |
three
AndyC |
May 7 2005, 09:04 AM
try again three
Attached image(s) |
AndyC |
four
Attached image(s) |
AndyC |
May 7 2005, 04:39 PM
Under the fuel tank, looks like the PO had a thing for red oxide primer
Attached image(s) |
AndyC |
May 7 2005, 04:41 PM
Looks like a nice layer of oil may have saved lots of work in the hell hole
Attached image(s) |
AndyC |
May 7 2005, 04:45 PM
Longs are very solid which is quite shocking after 15 years of British weather this is the only bit of rust that isn't superficial
Attached image(s) |
AndyC |
May 7 2005, 04:47 PM
Test fitting the new shocks and springs
Can you spot where I lowered it a bit too far before Attached image(s) |
mihai914 |
May 7 2005, 04:59 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I would put a layer of epoxy based paint and then some body filler, or if you find a good old bodyman with some lead experience. Maybe some rust converter before will also help.
Gint |
May 7 2005, 11:32 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
IMHO, that kind of pitting on exterior body panels that should be smooth and shiny should just be replaced. But that's just me...
AndyC |
May 9 2005, 10:06 AM
The lead soldering sounds interesting, I may have to grind the pitting back (as long as it hasn't gone all the way through) and learn the lost art of lead.
I do agree with Gint in that all the rusty metal should be chopped out and replaced but lead filling ontop of good metal is as good as new metal right? 914s are a rare comodity here and parts cars without rust in the same places are pretty much non existent. The last complete screen fame I saw for sale was about £1500 Does anyone have any experience with lead or am I on my own with this one? I definately want to avoid plastic body filler except for final smoothing out where it cant be avoided Either that or I will have to learn to fabricate sheet metal which could be a challenge |
Lo-Fi Version | Time is now: 17th May 2024 - 12:30 AM |
