914-6 part for 914rubber |
porbmw |
Apr 9 2017, 05:18 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
I'd be in for two... (IMG:style_emoticons/default/beerchug.gif)
Mikey914 |
Apr 9 2017, 06:26 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Guys this is a pretty easy one to make. Can anyone get me the fits to dimensions ?
ID of hose and hole? Metal thickness. Mark |
6freak |
Apr 10 2017, 07:42 AM
Is that seal for the hanger or a through the body grommet? (IMG:style_emoticons/default/confused24.gif) its goes on back fire wall around starter wires |
Mikey914 |
Apr 10 2017, 08:02 AM
SO, is it the same as the hole fro the starter wires? Or are there 2 different parts?
Becomes really easy and inexpensive when everyone needs these. Yes, I'd do this for the 6 guys, but if we all need it.....well you get my point. |
aturboman |
Apr 10 2017, 09:25 AM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
999 702 132 50 is a starter cable grommet for 3.2 Carrera 84-86
999 702 088 50 is the grommet for the oil line on 914-6 where it goes through the engine compartment sheet metal 999 702 089 50 is the grommet for the oil line support "hook" Porsche superceeds the 999 702 088 50 to 999 702 132 50 but its not really correct the original has a much larger center hole to accommodate the oil line OD. I suspect it can be made to work but you should copy the correct original style part if you're going through the trouble. 999 702 089 50 is NLA last time I checked, then again check your dealer they are re-issuing parts all the time. |
Mikey914 |
Apr 10 2017, 09:44 AM
Thanks I get the idea now. As with superseded parts one can be made to fit the other. As the later one exists I will make the "correct" early one as soon as I can get a sample. So on the oil line and the hole it passes through if someone can PM me the dimensions I will add to my notes to make sure this fits properly.
Thanks, mark |
Mark Henry |
Apr 10 2017, 10:05 AM
My tank holes I used a template but have a DWD tank and the holes don't line up exactly. If you were to reproduce them it would be nice if the OD lip was oversize so that there's a bit of wiggle room to offset the seal.
Mikey914 |
Apr 10 2017, 10:16 AM
I'll look at that. may be worthwhile unless it creates clearance issues with cross referenced parts.
Mark Henry |
Apr 10 2017, 10:26 AM
My tank holes I used a template but have a DWD tank and the holes don't line up exactly. If you were to reproduce them it would be nice if the OD lip was oversize so that there's a bit of wiggle room to offset the seal. I'll look at that. may be worthwhile unless it creates clearance issues with cross referenced parts. Or if the ID was tight the customer could trim the offset in the center hole of the seal. |
Mikey914 |
Apr 10 2017, 12:39 PM
The original part looks like it is a stretch fit. So it should do just that. If I can get an actual measurement off the hose line I can confirm, but I's suspect it's set up that way already.
6freak |
Apr 10 2017, 02:03 PM
i'm pretty sure that's a grommet for one of the oil tank tubes, probably the small one at the top for the breather hose The holes through the inner fender don't have grommets, they have foam collars in between the tank and the inner fender. correct! none of them.. The two parts in question will not interchange the oil line rubber is much bigger ID and smaller OD yet thicker then the firewall piece..I need that oil hose piece mike, the home made version is just not as clean (IMG:style_emoticons/default/biggrin.gif) |
6freak |
Apr 10 2017, 02:27 PM
The original part looks like it is a stretch fit. So it should do just that. If I can get an actual measurement off the hose line I can confirm, but I's suspect it's set up that way already. the wire grommet on the firewall pops in easy and wires push right through,,the other should be snug on the hook, but not tight on the hose ,the hook just cradles the hose and the hose moves inside the grommit (IMG:style_emoticons/default/smile.gif) |
Apr 11 2017, 02:14 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Here's an item to add to the list. Oil filter console seal. $42 list price. I pay less than list but it's still pricey. I could use a couple more. The O ring was $4 and the seal for the oil cap is $8.
Mikey914 |
Apr 12 2017, 12:19 AM
Ya know where to send them right?
Yes these are a bit steep for what they are. (IMG:style_emoticons/default/biggrin.gif) |
6freak |
Apr 12 2017, 06:40 AM
Here's an item to add to the list. Oil filter console seal. $42 list price. I pay less than list but it's still pricey. I could use a couple more. The O ring was $4 and the seal for the oil cap is $8. that console seal is a MOFO to install IIRC (IMG:style_emoticons/default/smile.gif) |
Apr 12 2017, 10:04 AM
Ya know where to send them right? Yes these are a bit steep for what they are. (IMG:style_emoticons/default/biggrin.gif) I'll have to buy another set. These are going in my car today. |
raynekat |
May 8 2018, 10:43 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Any word on reproducing these NLA grommets for the 914-6 oil lines?
porschetub |
May 9 2018, 12:08 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Well couldn't even find them @ the time ,with my tank for a test fit there is a need for seals no question,the tank isn't supposed to be close to the body anyway.
For lack of a solution I made tank seals from closed cell foam worked fine and checked on at not so happy ''reasons for removal" (4 times)....hopefully not out of the car again ?????? As fairly simple parts they need to be made again.....Mark ?? |
May 9 2018, 05:07 AM
I got the foam seals from my Porsche dealer but they were pricey.
burton73 |
Feb 11 2023, 01:01 PM
burton73 Group: Members Posts: 3,555 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Lo-Fi Version | Time is now: 11th June 2024 - 07:24 AM |
