transmission guys, you know who you are |
ws91420 |
May 7 2005, 11:57 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
I'm replacing the synchro rings in my trans. Is there a trick to hold them in place while putting the 'snap ring back on? First gear no problem. The others let's say I've been using a few choice words.
bondo |
May 7 2005, 01:26 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Are they clean and dry? they "should" stick in place well enough to get them together. But then I could be wrong, I haven't actually reassembled a trans yet. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Bleyseng |
May 7 2005, 01:47 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
It is a bit tricky, but you must be using the wrong "choice" words. Try some other ones and you'll get them in. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Dr. Roger |
May 7 2005, 05:39 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
I've found a touch of grease helps get lots of things where they need to be...
And helps things stay put. |
ws91420 |
May 8 2005, 09:38 AM
Okay guys I need a good answer. I get the ring in there and it under tension because you have to compress it slightly. Go to put on the snap ring it pops out. HELP (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Bleyseng |
May 8 2005, 11:43 AM
I am not at the shop but IIRC you have to get all the rings and things aligned just right so they do pop in.
brp914 |
May 8 2005, 12:07 PM
Unregistered |
it is sort of a pain, but I held down the sync ring/snap ring on a table top with one hand while using the snap ring pliers with the other. If that isn't working, perhaps you could put it all in a soft jawed vice. The gear is wider than where you need to apply force, but with a couple pieces of wood cut to size you should be able to hold things in place. Hope it helps.
Red-Beard |
May 8 2005, 12:18 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Well, knowing how to swear in German is a must. Consult Andy for the most appropriate ones for this situation. The parts will not respect you when being sworn at in English. They will ignore you at best. #1. I use a modified pair of snap ring pliers which give me a little more extension. I filed the inside of the handles. #2. Expand the synch band a little. This will give you a little more interference fit and hold it in place. Usually I run into this problem when I flip synchros not when I relplace. I would look at your dog teeth for wear. #3. If you are not replacing the dog teeth and the slider, make sure you clean up the slots on the sliders and repoint and clean up the dog teeth and slider points as best you can. Look at my article to tell whether dogteeth and sliders are re-usable.
Grease will not help in this situation. It should have a slight mechanical interference fit. James |
Lo-Fi Version | Time is now: 17th May 2024 - 06:17 PM |
