72 1.7 djet, intake manifold connections |
echocanyons |
May 7 2005, 12:22 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Could someone please describe the intake manifold connections on the 72 1.7 D-jet?
Pictures without the filter housing would be nice too. I am particularly interested in the 3 connections on the passenger side of the the mainfold and there routing. I have a huge vacuum leak because I cannot find the connection for one line. The vacuum diagrams on pelican are not the same as mine. |
LukeD |
May 7 2005, 12:46 PM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
Don't know how much help these will be(bad lighting) But here they are.
Luke Attached image(s) |
LukeD |
May 7 2005, 12:47 PM
123123
Attached image(s) |
LukeD |
123123123
Attached image(s) |
LukeD |
May 7 2005, 12:48 PM
Where does the one line come out of? Off that "T" thing?
Damn, I should just drive out there (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Damn mothers day weekend. As you can see I am just sitting here on the computer while my wife is out shopping. Kids are watching TV (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Sorry Kelly (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Luke |
Bleyseng |
May 7 2005, 01:50 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
You mean the AAR valve hookup? Thats kinda the bitch to fit in....
echocanyons |
May 7 2005, 04:18 PM
No problem Luke thanks for the pictures, I got it started and bypassed the cold start injcector and that resolved my smoking porblems, I think it was stuck on full open.
On the passenger side of the intake manifold I have one line going to the decel valve, one going to the MPS and one loose. |
mihai914 |
May 7 2005, 04:22 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Try This diagram
echocanyons |
May 7 2005, 04:26 PM
Thanks but that diagram show only one line off of the passenger side of the manifold mine has three
echocanyons |
May 7 2005, 04:30 PM
here is a picture
Attached image(s) |
echocanyons |
May 7 2005, 04:33 PM
Two is hooked up to the MPS and three is hooked up to the decel valve or whatever the arrow is pointing to in this picture
Attached image(s) |
Bleyseng |
May 7 2005, 04:40 PM
#1 connects to the PCV valve on the oil breather.
#2 goes to the decel #3 MPS |
echocanyons |
May 7 2005, 04:54 PM
Thanks Geoff!
echocanyons |
May 7 2005, 05:19 PM
Geoff, I got the oil breather that was my loose vacuum
but when I switch the two and three around it wont start at all. Are you sure #2 should go to the decel and #3 should go to the MPS? |
echocanyons |
May 8 2005, 10:52 AM
LukeD |
May 8 2005, 11:13 AM
The #2 goes to the MPS on my car. I don't have number 3 cause I have no decel valve.
Luke |
echocanyons |
May 8 2005, 11:22 AM
Since the decel valve is US only equipment (and not even standard on all US years) could/should I delete it?
Why was it not on the euro motors? |
Bleyseng |
They should all be open ports so all that matters is the correct hose size to each so you have a good seal. The other issue is do you have the correct and good PCV valve on the oil breather?
It should start but maybe with a high idle if you have a leak somewhere. |
Bleyseng |
May 8 2005, 11:29 AM
This one is missing the PCV Valve.
Attached image(s) |
Bleyseng |
May 8 2005, 11:37 AM
PCV
Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 02:08 PM |
