Finally Pulled the Heads, Not What I expected At All |
Jake Raby |
May 9 2005, 09:57 PM
Do you have a more clear pic of the combustion chambers???
d7n7master |
May 9 2005, 10:39 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hope this is not too BIG. You might want to step back a bit. Attached thumbnail(s) |
d7n7master |
May 9 2005, 10:41 PM
and one more.
Jake Raby |
May 9 2005, 10:48 PM
damn, looks like they have seriously been flycut...
Anyway, I thought I saw signs of a piston bumping against the head and thats a sure sign of a wiped rod bearing... But it appears to be okay.. |
d7n7master |
May 9 2005, 11:02 PM
Well something made those shiny marks & it wasn't me (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Guess I should un-wrap your video now (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) Thanx |
Jake Raby |
May 9 2005, 11:07 PM
Yep, watch the video...
Normally if a pison bumps into a head it is very apparent, more than what I see in the pics.. One thing is for sure- It was running rich.. Rich= fuel contaminated oil..... Fuel contaminated oil= Spun bearing WAY faster than normal.. Check journal #2 for a bad bearing first, its the first to go if you have an oiling issue, it gets it's oil last and not quite as much of it generally, especially at low RPMs with heavy load... #4 is next to go so check it too... |
d7n7master |
May 9 2005, 11:18 PM
It ran rich alright - for years - on D-Jet So do you think that maybe my "rich" d-jet could run my new 2165 w/out a lean condition? It's got a mild F.I. compatible hydraulic cam & lifter set.
Uh Ohh, I said hydraulic & d-jet (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Jake Raby |
May 9 2005, 11:58 PM
The problem with FI and larger engines is they simply try to lean out at peak torque- right where you are typically cruising..
D jet with the delayed valve events of a hydro cam would be pretty much a recipe for a nightmare IMHO... But if you tossed the brain for a programmable modern system you could preobably pull it off easily, even with stock injectors... Why the hell are you going to use the hydro cam?????? I have an M59 fragmentation grenade that would probably be just as effective if you pulled the pin 3/4 the way out and zip tied it to the valve cover bail... Seriously, you are going backward explore the possibilities of solid lift closer. |
messix |
May 10 2005, 12:15 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what is that in the second picture left cylinder upper right of the intake valve. looks rough, is it ? something beating around on it? a bent valve or debris. hows the piston look on that cylinder?
SpecialK |
May 10 2005, 01:59 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I see what looks to be a big hairy-ass crack (not to be confused with Z's big hairy "ass-crack") between the exhaust valve (left side) and the sparkplug hole......but then again, I see them everywhere.....ALL of my 2.0L heads have them (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Lo-Fi Version | Time is now: 29th April 2024 - 07:53 AM |
