-6 engine test stand drawings |
mb911 |
Apr 11 2017, 07:18 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
My engine is still in various states of the rebuild. I was wondering if anyone else had some drawings that they would be willing to share so I can build a test stand while I am waiting for the case to come back from the machine shop.
GeorgeRud |
Apr 11 2017, 09:35 PM
I have an engine stand ring adapter and an extra 914 transmission sitting in Fontana if that would be helpful for you. They're just taking up space in my garage right now.
George |
mb911 |
Apr 12 2017, 06:48 AM
I have an engine stand ring adapter and an extra 914 transmission sitting in Fontana if that would be helpful for you. They're just taking up space in my garage right now. George George for running the engine or just for tearing an engine down? I want to make one for running the engine |
GeorgeRud |
Apr 12 2017, 07:37 AM
No, it's just the engine tear down ring. You probably need something more, but I didn't know if the transmission would give you something to mount the engine (and a starter) and provide attachment points for a run stand.
Mark Henry |
Apr 12 2017, 08:34 AM
I don't think there's any plans out there just shop/home built examples.
Fair bit of work you'll need a tank, tach, gauges electrical fuel tank and pump. You can use a cut off trans bell housing and go from there. http://forums.pelicanparts.com/911-engine-...test-stand.html http://forums.pelicanparts.com/911-engine-...test-stand.html |
mb911 |
Apr 12 2017, 09:39 AM
I don't think there's any plans out there just shop/home built examples. Fair bit of work you'll need a tank, tach, gauges electrical fuel tank and pump. You can use a cut off trans bell housing and go from there. http://forums.pelicanparts.com/911-engine-...test-stand.html http://forums.pelicanparts.com/911-engine-...test-stand.html Thanks that does help with a few ideas. Looks like I will have to wait until I get the engine back together to make it. This will be a bit. Talked to Henry at supertec the other day. probably another month for case and then reassembly on my end could be mid summer before it runs.. I want it so I can doa basic setting of the carbs and do any tweaks then do some quick DB tests on some muffler designs before the car is ready |
gms |
Apr 12 2017, 10:34 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I would use a 911 engine cradle to mount the front of the engine
I would make the mount work with a 901 transmission attached There are ignition panels at Pegasus racing for starting and switching fuel pump and ignition I would use a round Peterson Dry Sump Oil Tanks because they are cheap I think I have an extra 911 engine cradle if you are in need |
gms |
Apr 12 2017, 10:49 AM
I probably have a spare empty 901 case as well
IronHillRestorations |
Apr 12 2017, 01:25 PM
I made one with a transmission case and a spare gauge panel and a mount for the oil tank. No plans though, just fab'd to fit.
mb911 |
Apr 12 2017, 01:56 PM
I made one with a transmission case and a spare gauge panel and a mount for the oil tank. No plans though, just fab'd to fit. I would have done that for sure had the engine been here but currently the case is in southern California.. Glenn probably just use my own oil tank that I make (IMG:style_emoticons/default/biggrin.gif) I have a 901 .. So part of the secret is that I plan to build my proto type 2 in 1 muffler based 100% off the original muffler internals with a spite twist on the exterior and need the test stand to use my heat exchangers etc.. |
Apr 12 2017, 02:18 PM
Our test stand is at another shop. I'll try to get a pic soon.
VaccaRabite |
Apr 13 2017, 07:28 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
They are easy to make. Put it on casters, low to the ground and with a cut out for the jack and it will double as an engine install and removal dolly. Here is how I did mine:
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-1435-1492090115.1.jpg) The engine and transmission and exhaust are all on, and the entire package can just be lifted into the car. Easy as pie. The control console is a separate stand. Zach |
Mark Henry |
Apr 13 2017, 08:44 AM
Can be done like Zack says, but a little more to it for a /6.
Why not just put it in the car? (IMG:style_emoticons/default/confused24.gif) With a big enough firewall cutout it's fairly easy to work on the timing and carbs. |
Apr 13 2017, 08:51 AM
I think for what Ben does - building heat exchangers, exhaust, etc., it makes sense to build a real stand that he can install and remove his heat exchangers easily, instead of working on the floor or under the car.
Mark Henry |
Apr 13 2017, 09:10 AM
I think for what Ben does - building heat exchangers, exhaust, etc., it makes sense to build a real stand that he can install and remove his heat exchangers easily, instead of working on the floor or under the car. I would imagine for that he'd have a dummy block upside down on a stand, that's how I've made headers for several 356 kit cars with T4 engines. I took it this was purely for engine test run/break in duties. |
Apr 13 2017, 09:14 AM
"So part of the secret is that I plan to build my proto type 2 in 1 muffler based 100% off the original muffler internals with a spite twist on the exterior and need the test stand to use my heat exchangers etc.. "
Mark Henry |
Apr 13 2017, 09:34 AM
"So part of the secret is that I plan to build my proto type 2 in 1 muffler based 100% off the original muffler internals with a spite twist on the exterior and need the test stand to use my heat exchangers etc.. " So is this for a /4 or /6? (IMG:style_emoticons/default/confused24.gif) For a four I can take a couple pic's on my test run stand. |
Apr 13 2017, 10:35 AM
"So part of the secret is that I plan to build my proto type 2 in 1 muffler based 100% off the original muffler internals with a spite twist on the exterior and need the test stand to use my heat exchangers etc.. " So is this for a /4 or /6? (IMG:style_emoticons/default/confused24.gif) For a four I can take a couple pic's on my test run stand. 6 - he's doing a conversion car. |
mb911 |
Apr 13 2017, 11:06 AM
"So part of the secret is that I plan to build my proto type 2 in 1 muffler based 100% off the original muffler internals with a spite twist on the exterior and need the test stand to use my heat exchangers etc.. " So is this for a /4 or /6? (IMG:style_emoticons/default/confused24.gif) For a four I can take a couple pic's on my test run stand. 6 - he's doing a conversion car. Correct the car is not even close to being ready and I can very easily build one once the engine pieces are back from various places on the globe but wanted to build something ahead of time. When I do headers etc I had my dummy block for that but that has turned into my engine build ( I have real fixtures now) so I am out of luck on that but again the point is to be able to do some real testing and running while I finish up the car probably over the next 2 years and I need to be able to test the muffler here before I offer it as a new product. I can't depend on others for feedback if I don't have a baseline to go from on my end. So you ask what do I really need to know for dimensions. What would be particularly helpful would be from the original six engine mount (engine side) to the transmission mounting ears. if I had that true dimension I could build whatever I want from there.. |
Apr 13 2017, 01:28 PM
Here's ours
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:57 PM |
