73 2.0 injected idle |
chrisf |
Apr 14 2017, 01:55 AM
Newbie Group: Members Posts: 13 Joined: 16-March 16 From: canada Member No.: 19,757 Region Association: None |
Has anyone encountered an idle where its at 1700rpm unless you let the clutch out just for a sec to bog down the engine then it idles fine at 1000rpm?or if you down shift through the gear which allows the engine to slow down? could it be the distributor? and has anyone installed a new distributor from 123igintions?
Also how well does your 914 stop if need be eg( emergency stop)are the 914 brakes weak, do most people upgrade? Thanks guys |
ndfrigi |
Apr 14 2017, 02:04 AM
Shadowfax |
Apr 14 2017, 06:24 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Stock brakes are not weak. My car stops on a dime. There are upgrades of course but in good condition the stock system is more than adequate. Check the condition of your pads, rotors, soft lines, fluid and see if the calipers are working correctly. Also check the venting clearance on the rear brakes.
Apr 14 2017, 11:19 AM
I have had an idle similar to that described when the advance in the distributor was hanging up. A good clean and re-lube of the advance mechanism should help with that.
Vacuum leaks are always a possibility, of course. The stock brakes are woefully inadequate--if they have been sitting un-tended for 20-40 years. If the system is in top condition, they really work quite well. It helps that there just isn't that much mass to stop. --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 05:11 PM |
