What is this ? |
What is this ? |
tp_reading |
Apr 14 2017, 10:54 AM
Member Group: Members Posts: 58 Joined: 4-May 15 From: United Kingdom Member No.: 18,698 Region Association: None |
Apr 14 2017, 11:11 AM
Looks aftermarket. The electrical tape, the in-line fuse, the semi-insulated crimp-on connector (yellow insulator on the right) are all give-aways for that.
Could be just about anything. From powering an electric windshield washer pump, to a quickie anti-theft switch, to... Well, anything someone could use their imaginations for! I really don't like that it appears to be bare metal with current flowing through it. That seems like a great way to pop fuses, or if you're really unlucky, start fires. Trace the wires--where do they go? --DD |
Mueller |
Apr 14 2017, 11:19 AM
Toggle or rocker switch that is missing a bunch of parts.
tp_reading |
Apr 14 2017, 11:27 AM
Toggle or rocker switch that is missing a bunch of parts. Yes I figured it was a broken rocker switch. Odd that it was hidden behind the fuel gauge, impossible to get to without pulling out the gauge, I guess I will have to trace the wires, but it's a real mystery. |
914Sixer |
Apr 14 2017, 02:41 PM
Home made kill switch.
tp_reading |
Apr 14 2017, 03:40 PM
I have discovered some crappie workmanship on my car, but this bit of wiring is the worst ! |
Lo-Fi Version | Time is now: 16th May 2024 - 07:09 AM |
