Oil leak, Oil cooler |
J123young |
Apr 15 2017, 05:50 PM
Member Group: Members Posts: 50 Joined: 1-February 17 From: Fenton, MO. Member No.: 20,801 Region Association: None |
So above the oil filter I have a leak. I'm guessing it's the oil cooler. But I can't see anything...can this be fixed without pulling the motor?
If I have to pull the motor, how big a job is it and what else should I replace while its out? It's a 74' 1.8 |
McMark |
Apr 16 2017, 06:42 AM
Changing oil cooler seals can be done in the car, but if you haven't practiced pulling the whole motor, you should do that. It makes the job much easier and gives you better access to make sure the job is done right. And once you've done it a few times removing the engine and transmission is easy.
Use this removal guide. Also, it could be a leak from the oil pressure switch, or from the oil filler/breather box. Reseal those as well. And if you really want a dry engine, reseal the front crank, oil pump, etc. (IMG:style_emoticons/default/biggrin.gif) |
saigon71 |
Apr 16 2017, 10:41 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Yes, check the oil pressure sender first.
I replaced my oil cooler seals with the engine in the car. It's a little tight, but not a bad job. If you verify that its the oil cooler seals causinv the leak, I'd replace them without pulling the engine. Use an open-ended wrench to hold the seals in place while starting the bolts. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:26 AM |
