GB: 914-6 Oil Line Hook -- CLOSED, Restoration Design will be making more... |
peteyd |
Apr 19 2017, 12:53 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I started using Fusion360 to design things. It's working pretty well, but now I can't figure out how to get my designs out of F360 and to the cutter. This step drives me totally bonkers -- I don't understand how the rest of the CAD/Design industry works if there's no interoperability between platforms. (IMG:style_emoticons/default/wacko.gif) Anyone know F360 well? If nothing else, I'll just redraw it with my old system. Gonna place the work order next week and then contact everyone. Mark, save your file as a dxf or dwg. Whoever youre getting to cut it will be able to use that file type. Pete |
McMark |
Apr 19 2017, 01:03 PM
I started using Fusion360 to design things. It's working pretty well, but now I can't figure out how to get my designs out of F360 and to the cutter. This step drives me totally bonkers -- I don't understand how the rest of the CAD/Design industry works if there's no interoperability between platforms. (IMG:style_emoticons/default/wacko.gif) Anyone know F360 well? If nothing else, I'll just redraw it with my old system. Gonna place the work order next week and then contact everyone. Mark, save your file as a dxf or dwg. Whoever youre getting to cut it will be able to use that file type. Pete Yeah, I can save DXF, but they can't open it. Here's a test file... Attached File(s) Fusion360Test.dxf ( 2.1k ) Number of downloads: 32 |
mb911 |
Apr 19 2017, 01:44 PM
914 Guru Group: Members Posts: 6,831 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I want one as well
Montreal914 |
Apr 19 2017, 01:58 PM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
2D files; DWG or DXF
3D Files; STEP, STL, IGES, others... Seems like you got it. Here is a screen capture of your test file that I opened with SolidWorks. Good luck. I started using Fusion360 to design things. It's working pretty well, but now I can't figure out how to get my designs out of F360 and to the cutter. This step drives me totally bonkers -- I don't understand how the rest of the CAD/Design industry works if there's no interoperability between platforms. (IMG:style_emoticons/default/wacko.gif) Anyone know F360 well? If nothing else, I'll just redraw it with my old system. Gonna place the work order next week and then contact everyone. Mark, save your file as a dxf or dwg. Whoever youre getting to cut it will be able to use that file type. Pete Yeah, I can save DXF, but they can't open it. Here's a test file... |
6freak |
Apr 19 2017, 03:30 PM
Is Mikey (914Rubber) making the grommet for the hook to protect the line? There's talk... (IMG:style_emoticons/default/hide.gif) its needed probably more then the hook...JMO (IMG:style_emoticons/default/smile.gif) |
wndsnd |
Apr 19 2017, 07:03 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
If I can make a suggestion of giving it some extra length to allow for some wiggle room. We can always shorten them up a bit.
McMark |
Apr 20 2017, 10:24 AM
Okay, I got my drawing issue sorted out. I was making a couple mistakes, so I learned something new.
Thanks for confirming, Montreal914. It may not have seemed like much, but your input led to me to the solution I needed. (IMG:style_emoticons/default/smiley_notworthy.gif) Once I get the actual pieces in hand and confirm they're correct I'll contact people and post purchasing info. |
McMark |
Apr 25 2017, 06:45 AM
Pick up the parts today. (IMG:style_emoticons/default/piratenanner.gif) The picture looks a little off because the new part isn't sitting at the same angle as the original part.
Before I send them out, I'm ordering a sample grommet from McMaster-Carr that might work well for this. Should be here tomorrow. Attached image(s) |
Cairo94507 |
Apr 25 2017, 07:04 AM
Michael Group: Members Posts: 9,738 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nice work. (IMG:style_emoticons/default/beerchug.gif)
porbmw |
Apr 25 2017, 02:12 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Don't need the hook....
BUT Sure could use a couple of grommets.... (IMG:style_emoticons/default/beerchug.gif) |
Mike D. |
Apr 25 2017, 03:31 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'll have one too. just 1 too, not two. (IMG:style_emoticons/default/smile.gif)
Mitox |
Apr 25 2017, 03:58 PM
Member Group: Members Posts: 395 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
I'm in for one if it's not too late.
Dtjaden |
Apr 25 2017, 05:03 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I would also like one!
McMark |
Apr 25 2017, 08:59 PM
12? (IMG:style_emoticons/default/grouphug.gif) |
eyesright |
Apr 25 2017, 09:11 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Add me to your list. I need one for my '70 conversion. Thx. Sending PM.
McMark |
Apr 26 2017, 04:01 PM
Bought the wrong grommet... (IMG:style_emoticons/default/rolleyes.gif)
Fit the hook perfectly, but the ID was wrong. (IMG:style_emoticons/default/slap.gif) Lets try again tomorrow. |
forrestkhaag |
Apr 26 2017, 04:14 PM
I will take one if available. Paypal?
McMark |
Apr 27 2017, 07:24 AM
Got the new grommet today. Looks really good to me. ID is ~30mm, and should fit AN-16 snug. The one I bought yesterday was about ~22mm on the inside. The smaller grommet won't be part of this GB, but if you need that size you can order it yourself from McMaster.
Attached thumbnail(s) |
live free & drive |
Apr 27 2017, 09:40 AM
Member Group: Members Posts: 156 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
I'd like to get in on this group buy too - if possible.
PM sent. |
EdwardBlume |
Apr 27 2017, 09:43 AM
I'm in too! Thx
Lo-Fi Version | Time is now: 8th May 2024 - 09:33 AM |
