Another early handbrake question, Is there a return spring I am missing? |
theer |
Apr 22 2017, 07:32 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I have the early folding handbrake handle and getting the flashing light to go out is a two-handed process to get the switch fully depressed.
Is there supppsed to be a spring somewhere on the handle mechanism to help release the brake? Anyone got a picture? Thanks, Tom |
GeorgeRud |
Apr 22 2017, 08:25 AM
I've always had to hold the folding part of the handle up while moving the entire handle to it's resting position to close the switch and turn off the handbrake light. I'm unaware of any spring or other assist and there is no adjustment on the switch.
theer |
Apr 22 2017, 08:42 AM
Yup- that's exactly what I have to do.
Thanks for confirming. |
IronHillRestorations |
Apr 22 2017, 10:55 AM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
There's a compression spring inside the early handle.
cwpeden |
Apr 22 2017, 11:15 AM
I just took mine apart last week.
There is a spring at the yoke just before the firewall. Other than that it probably just needs cleaning and lube at the pivot and cable joints. Mine was frozen where the cable connects to the handle. |
theer |
Apr 22 2017, 12:52 PM
Hmm, I'm missing that spring at the firewall. I don't see where/how a spring connects.
Do you have a picture? |
theer |
Apr 22 2017, 12:53 PM
Everything is free and loose. Do you have a picture? |
Apr 22 2017, 01:51 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914rubber sells the spring
cwpeden |
Apr 25 2017, 10:32 AM
looks like this:
https://914electric.files.wordpress.com/201...4/handbrake.jpg |
McMark |
Apr 25 2017, 10:36 AM
The spring at the firewall is only on later cars. If you're using stock components an two-piece eBrake handle won't have the firewall spring ever.
There is a spring just behind the button, and there is a 'finger-spring' at the rear end of the pushbutton-rod. Those finger springs almost always break. But the symptom for that failure is that the pawl won't click against the teeth and the eBrake won't hold at the top when you set it. I got in the habit of pushing down on the joint in the middle of the lever after I release it. |
cwpeden |
Apr 25 2017, 10:49 AM
Learned something new. Couldn't remember if my 72 had one.
Thanks |
rgalla9146 |
Apr 25 2017, 11:00 AM
The spring at the firewall is only on later cars. If you're using stock components an two-piece eBrake handle won't have the firewall spring ever. There is a spring just behind the button, and there is a 'finger-spring' at the rear end of the pushbutton-rod. Those finger springs almost always break. But the symptom for that failure is that the pawl won't click against the teeth and the eBrake won't hold at the top when you set it. I got in the habit of pushing down on the joint in the middle of the lever after I release it. I agree with all of the above. The old handle is such a quirky mechanism that when it is set most drivers would not be able to release it. |
cwpeden |
Apr 26 2017, 09:42 PM
That's funny, it was the first thing I took out of my 72 and put in the 73. That and the seatbelts.
Lo-Fi Version | Time is now: 2nd May 2024 - 10:44 AM |
