The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
BRAVE_HELIOS |
Apr 22 2017, 02:13 PM
As a side note... I just took the car for a short drive; still with the Prestone Radiatior Flush and Cleaner running through the cooling system. I'm doing the heavy duty cycle cleaning... 3-6 hours of 'normal' driving. Of course, always with an eye on the temp gauge. Anyway; today after getting back from my short drive, I noticed that the overflow bottle in the trunk was actually bulging quite a bit. There is no pressure cap on it, just a simple snap type cap, yet it was definitely looking like it was under pressure. Temp gauge read around 180 and the electric fan was running.
Is this normal? Sometimes I wonder if I have the expansion tank plumbed correctly. Can you tell by looking at the pictures and descriptions that it is installed correctly? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:31 PM |
